for the dvi-hdmi lead, I presume the dvi is at the graphics card? you need to provide more information when you need help. What do you use as your primary audio device? If it is onboard sound then disable other sound sources such as HDMI. To do this go to "manage audio devices" in control panel. Assuming that you are using windows 7.
