Ive got a very strange problem, but first some specs
-Sabertooth 990fx R2
-AMD fx-8120 Bulldozer
-Hd 7950 3gb
-16gb corsair vengeance 1866mhz ram
-corsair GS 800 PSU
-2 corsair ssd's (Raid 0) and 2 Caviar HHD's (Raid 0)
I turned on my machine the other day, it booted up and there where lines all across my screen.. oh crap a graphics card problem. turned it off and on again and it wouldn't boot. Removed graphics card and put it in another slot, it worked... put it back in its original top slot and it all worked again... strange but ok, fine the HD 7950 has given me stupid problems in the past anyways so I will let this one slide.
For some reason now my front audio ( headphone) slot wont produce sound... even though it recognizes when I put in a headset or in my case a lazy way to plug my amp in (plugging an amp in a headphone jack isn't usually a problem is it?) oh and also the normal back panel analogue jacks wont produce sound but again recognize when i put it in and says everything is fine. The only place I can get audible sound from is the optical digital port on the back. they should be all coming from the same source right? so if ones broken then everything shouldn't work?
I've noticed if I keep plugging and unplugging headphones or my amp into the front port a few times my computer shuts down too <--- possibly a voltage problem?
Checked the cables inside the machine and they are all in the right slots, uninstalled the sound drivers completely and reinstalled the latest ones and still the same problem. checked the BIOS settings and everything is set correctly.
Any ideas on how to fix this problem?... apart from buying an amp that fits in the optical port 🙂
-Hd 7950 3gb
-corsair GS 800 PSU
