Sound problems with P3b-F
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
The following is from a friend who has a problem with his P3B-F and its
soundcard:
When I start the computer the sound is very low and appears to be mono.
I go into the control panel, then double click on Aureal Vortex Control
Panel. When this comes up all I have to do is click on the tab "A3D
Setting" and the volume becomes much louder and I have Stereo. I would
like to have the sound this way when I start the computer and not have
to go into the Control Panel but have not found how to do this.
Any help would be appreciated.
> soundcard:
Thinking out loud... Does your P3B-F have onboard sound? Sounds like a
driver/software problem, since volume is amplified when you run/start
your "A3D" program. Try reinstalling the sound card software/driver.
If that does not solve the problem, can you add the "A3D Setting"
program to the startup folder so it automatically loads?
My P3B-F and SoundBlaster Live! Platinum card does not experience this
problem.
Good luck,
Steven
