[SOLVED] Sound problems
Oct 31, 2018
5
Hello, i have recently bought a pc off ibuypower and i noticed that when i plug my heaphones in the motherboard it make electric noise and when i move my mouse it makes more noise. When i plug my headphones in the front jack it works perfectly. Is there any way to fix the electrical noises?
Grobe
Some motherboards are poorly designed. I have had some motherboards myself that had that kind of problem.
There is a couple of other things you may do in order to overcome this noise problem:
  • Add a new sound pcie card, and deactivate the old one.
  • Use headphones that use usb connection instead.
Or just continue to use the front jack output.
Grobe
