sound-xbox-monitor
G
Guest
Guest
Hello,
i have my xbox plugged into an acer lcd moniter, via a cable that is DVI to HDMI, but, i dont have and sound, any way i can plug in speakers?
1: Are you sure it isn't HDMI->DVI from the xbox to the moniter?
2: If your moniter doesn't have speakers, it won't output audio. You'll need to explain you're setup a bit more so we can figure out what needs to be done to connect speakers to the Xbox's audio outputs.
Similar threads
