Question Soundbar with cable volume controller
captain1997
6
Hello,
Can anyone suggest me a good soundbar with cable controller for volume like the one that many ordinary speakers have? Or should i buy a soundbar and an external volume controller instead and add them together?
delaro
Splendid
Herald
How do you plan to connect your soundbar? If you connect it analogue (3.5mm AUX cable), you can get simple analogue in-line control (basically, a stereo potentiometer) between the source and the 'bar.
Most TV's don't have a 3.5mm connection, you also see RCA's being left off now as well. Connecting Via HDMI or S/PDIF should allow you to control the volume the same way as you would the TV speakers since your going to be bypassing them for the Soundbar.
