Hey guys,
I just bought a PS4 Slim (which doesn't have an optical SPDIF connection). So I started to look how I could get the sound from my PS4 slim transferred to my Computer to listen to it while still being able to sit in Teamspeak and talk with others without having to listen to it over Speakers/extra headphones connected to the PS4 Controller.
I came across a solution which leads me to connect my PS4 slim to a TV/Monitor via HDMI which has optical SPDIF which then should be connected to my Computer. Technically that should work out but I dont have an optical SPDIF connection on my motherboard and therefore would need to buy a soundcard. I came across some which list only "SPDIF OUT".
(Asus Xonar DG)
My question is now: Is SPDIF working both ways or will SPDIF OUT not work for what I have planned? Or is there another way to achieve this? My Monitor also has a headphone jack which will switch the sound output to headphones when they are connected but somehow will not switch if I connect the headphone jack via a 3.5mm x 3.5mm cable as an audio linein to my computer. Could that work and if so am I doing it wrong?
Thanks in advance
Thank you very much in advance
(Asus Xonar DG)
Thanks in advance
