Hey. I could really use some words of wisdom here. I recently purchased a Marantz PM6005 amplifier and Polk tsx220b speakers to go with it. The amp is hooked to my PCs soundcard via S/PDIF. I always assumed that when you use S/PDIF, you cannot even change the volume level from the source, since only the music is sent digitally as ones and zeros.. but to my surprise I found out that the windows volume adjustment works normally (as does the volume adjustments in media players). So my question is, on which level I am supposed to keep my source volume (windows pc, music played with itunes): I have gotten so mixed information on this. Someone mentioned on this forum that I should have the PC volume maxed out and only control the volume from the amp, yet on another forum someone said I should keep the PC volume on 50% cos this is somehow supposed to make the sound better and tmake the amp perform better. Getting really confused here.
Also, I've noticed that when im listening to music really loud, some bass frequencies start to distort. Still the volume level is something the amp and the speakers should easily handle. Could this be due the fact that ive had my PC volume at 90% and I should set it lower and increase the volume from the amp? (itunes player volume has been always on max)
Any advice would be greatly appreciated.
