SP2 problem on Dell dimension 8400
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
Hi,
I had a client with the above mentioned computer, P4 3.2GHz, 1 Gb ram. I
service packed the computer from an update cd. XP home. The update went
smoothly, computer finished off and rebooted. It rebooted straight into
widows which, I found strange, no screen about turning on automatic updates.
On trying to open up "my computer" or internet explorer nothing would
happen. Other programs, control panel, etc worked. Thinking I'd rushed in
too fast or something, I gave the computer a reboot and had the exact same
problem. Thinking maybe a reinstall of IE would solve the problem, I loaded
my cd, then realised I was unable to access the cd drive because of the
problems... At this point I took the easy way out and uninstalled SP2, at
which point things went back to normal. Anyone have any ideas?
map
783
"k1w1" wrote:
> Hi,
A place to start.
http://support.dell.com/support/topics/global.aspx/support/kb/en/document?dn=1090448&c=us&l=en&s=gen&cs
