SP2500's or Another Subwoofer?
yogman
175
Hello!
I have a question about upgrading my computer audio.
Currently, I have the Logitech Z623 computer speakers. They're alright, but the sub isn't tremendously powerful and generally, I've heard that the audio isn't that great compared to some other speaker systems.
But, because my main reason for upgrading is more bass, would it be better to replace my current speakers with the Corsair SP2500? Or get a home theater subwoofer that I could hook up to my sound card to replace or run in tandem with my current sub?
(Oh and I have an Asus XONAR DX sound card)
Opinions?
Thanks!!
-- Yogman
Im a professional electronic music producer and The Corsair sp2500 is such a good system that I replaced my studio monitors with it. I needed something with a full bass response and subwoofer that was correctly integrated with a nice crossover and balanced for the sattelites. It truly is going to blow you away with how good it is and trust me the bass response is there! I use it in the default EQ settings for my studio work (really flat colorless response) but there are some great preset settings on it optimized for gaming and movies and music, you won't be disapointed.
Moving up from a Logitech system you'll be amazed, Logitech makes a good surround sound setup for cheap....but the quality of speakers and electronics is designed to...
Moving up from a Logitech system you'll be amazed, Logitech makes a good surround sound setup for cheap....but the quality of speakers and electronics is designed to give you "bang for your buck" instead of quality of sound. It's definately a big step up from that in the Corsair. It's obvious they wanted to take the market by storm with these because to get comparable quality you're gonna have to spend twice as much and get a 2.1 set of KRK Monitors and sub (I had enough set aside to get either one and still went with the corsair).
