Speakers Hum/Buzz When Ethernet is Connected?
username77
Commendable
Dec 5, 2016
12
I have an analog receiver connected to a laptop via an RCA to 3.5mm jack adapter then a 15 or so ft 3.5mm cord running to the laptop. The speakers that are connected to the receiver, when on the laptop's input, play FM radio.. even when the FM antenna is pulled from the receiver. Recently, I ran a CAT 6 Ethernet cable to the laptop and now the FM radio volume has increased, and a loud buzzing sound has started coming from the speakers that are connected to the receiver. As soon as the Ethernet cable is unplugged, the humming stops. How can I fix this?
Thanks or the quick reply, sorry I just saw this. I will order the ground loop isolator and update from there. Thanks again!
Update: I did not end up ordering the ground loop isolator because I have rearranged the laptop and speakers and they are closer now so I used a shorter cord and it has solved the problem but i'm sure your answer would have resolved it so I will choose yours as the solution.
Thanks.
