Speakers out of sync with streaming audio.
SoulXD
Commendable
May 29, 2016
42
As the title states, when I am watching twitch, youtube, etc. the audio will progressively get more out of sync the longer I watch a video/stream. What is strange though is when I switch to my headphones, audio is fine. Then when I switch back to my speakers, it's all good again. Though the audio will still get out of sync.
I have tried to use different audio jacks on the motherboard and it didn't change anything. If it is a speaker problem, that wouldn't be too big of a deal because it's just a set of cheap speakers 😛
If the speakers are the potential problem, any recommendations for speakers? (nothing too crazy expensive, no more than $30)
What browser are you using? If Chrome try enabling or disabling hardware acceleration under advanced settings.
The reason I assume Chrome is that I am having the same issue. I had acceleration turned off and the desync was out of control. With it on, it is working correctly, for now.
You can also test this by using a different browser for a while and see if it occurs across them as well.
Here is another thread with the Chrome issue: http://www.tomsguide.com/answers/id-3538515/youtube-hardware-acceleration.html
I am using chrome and have already tried disabling hardware acceleration 🙁 Just tried Edge and still having the same issue.
Speakers are 3.5mm and headphones are usb
Hi,
I am also having the same issue, from what i can remember it started when the new NVIDIA graphics drivers got released.
Have tried all the suggestions above as well as re-installing both graphics and audio drivers with no success.
I will be watching a YouTube video, Twitch stream, Netflix, pretty much any platform and this problem will happen.
Slowly the video will start to lag a few seconds behind the audio and progressively get worse, refreshing the page restarts this loop.
After reinstalling my drivers the problem went away for a few days then returned.
Now if i try to do the same fix it will not work.
Any suggestions would be much appreciated,
Kind regards.
