B Bear1941 Commendable Mar 21, 2016 1 0 1,510 Mar 21, 2016 #1 I am running surround sound through the subwoofer, the speaker just fine but not a squeak out of the subwoofer. I tried wiring it direct to the amplifer and that did not work either.
Solution ssddx Mar 21, 2016 if you expect help you need to better describe your connections including model numbers and brands. no clue what you're doing based on what you said.
ssddx Titan May 27, 2009 17,050 5 74,965 Mar 21, 2016 Solution #2 if you expect help you need to better describe your connections including model numbers and brands. no clue what you're doing based on what you said. Upvote 0 Downvote Solution
