[SOLVED] Speed and Latency question
vwcrusher
594
13
10,995
In the process of specifying and gathering parts for new build; intended use is video editing with Premiere Pro and some gaming. Below is the parts list (items with $0 are in house). I should mention that at some point some mild overclocking may be performed.
After reading this forum and other sites, it seems that 3200 speed might be best (as opposed to 3000)? Also, I am not sure which latency spec to use......16 at the moment?
Thanks for the help.
PCPartPicker part list: https://pcpartpicker.com/list/WF6fcY
Price breakdown by merchant: https://pcpartpicker.com/list/WF6fcY/by_merchant/
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor ($529.89 @ OutletPC)
CPU Cooler: Noctua - NH-D15 82.5 CFM CPU Cooler ($89.95 @ Amazon)
Motherboard: Gigabyte - Z390 AORUS ELITE ATX LGA1151 Motherboard ($165.39 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 Memory ($234.99 @ Newegg Business)
Storage: Samsung - 970 Evo 500 GB M.2-2280 Solid State Drive ($127.99 @ Amazon)
Storage: Samsung - 970 Evo 1 TB M.2-2280 Solid State Drive ($247.99 @ Amazon)
Storage: Western Digital - Caviar Black 4 TB 3.5" 7200RPM Internal Hard Drive ($0.00)
Video Card: EVGA - GeForce GTX 1070 8 GB FTW Gaming ACX 3.0 Video Card ($0.00)
Case: Fractal Design - Design Define R6 USB-C - TG ATX Mid Tower Case ($0.00)
Power Supply: SeaSonic - FOCUS Plus Gold 750 W 80+ Gold Certified Fully-Modular ATX Power Supply ($0.00)
Monitor: LG - 34UM59-B 34.0" 2560x1080 75 Hz Monitor ($0.00)
3200 ram will only outperform 3000mhz by a small amount in games and some workloads, however if you can find 3200 kit for a similar price to the 3000 kit, i would go for the faster 3200 kit. Likely you could xmp a 3000 kit to 3200mhz. Also on another note you might want an AIO for that cpu since air cooling with an overclock on a 9900k can lead to some toasty thermals. If you are only going to oc a little bit you will be fine with the d15.
vwcrusher
594
13
10,995
Thanks for the reply; I will see what the price difference is between the 3000 and 3200.
The other issue is latency.....given the work load and system profile, would 16 suffice or go with 14?
Regarding thermals, I don't see anything more than mild overclocking....I was thinking either the Noctua D15 or D15S or possibly the Be Quiet Dark Pro 3....just concerned about RAM interference. Do you think I am ok with that?
Again, thanks.
I do not know much about how much ram timings affect performance. You usually can take a kit with loose timings and tighten them up. For mild oc you should be fine with any of the above coolers. I would pick your ram and then worry about what coolers will clear your ram.
vwcrusher
594
13
10,995
MERGED QUESTION
Question from vwcrusher : "RAM speed and latency"
After reading this forum and other sites regarding the 9900K and MB, it seems that 3200 speed might be best (as opposed to 3000)?
PCPartPicker part list: https://pcpartpicker.com/list/y9PwJ8
Price breakdown by merchant: https://pcpartpicker.com/list/y9PwJ8/by_merchant/
CPU Cooler: Noctua - NH-D15S 82.52 CFM CPU Cooler ($79.90 @ Amazon)
Storage: Samsung - 970 Evo 500 GB M.2-2280 Solid State Drive ($127.96 @ Amazon)
