Speed of USB vs. Paralell Port Scanners?
G
Guest
Guest
Archived from groups: alt.comp.periphs.scanner (More info?)
I have an old Umax 1220P (parallel port) scanner on a 1.2 gHz Athlon & 256
MB RAM ( USB 2.0 available).
I need to make black & white scans of 8.5" x 11" line art drawings at 1200
DPI.
The Umax 1220P takes about 7 minutes to make such a scan.
Will a more modern consumer grade USB scanner be appreciably faster?
Thank you,
Mark D. Fain
In article <5p6dnflTGJZAyj3dRVn-hA@bright.net>, fain@brightdsl.net
says...
> DPI.
> Thank you,
> Mark D. Fain
Yes.
The info bus is faster, but just as significantly, the scanners
themselves are faster.
Also, your scanner is only 600 ppi optical, so you've been interpolating
up to 1200 all this time rather than getting actual 1200ppi sampling.
Mac
On Tue, 11 May 2004 00:34:37 -0400, "Mark D. Fain"
>DPI.
>Thank you,
>Mark D. Fain
Mark,
Just tested for you - the Epson Perfection 1670 (USB 2.0) takes 2min
25sec to scan full A4 size at 1200dpi on Athlon 1.7Ghz Preview was 5
seconds. This model is supposed to be three times faster than the
previous 1600 series Perfections.
Picture quality is better (IMHO) than UMAX's. I just upgraded from
UMAX 1200S which was disappointing speedwise even for SCSI.
-Dave Chiew
Thank you for taking the time to run this test for me. The Epson 1670 was
one of the scanners I was thinking of upgrading to, so your info is perfect.
Thanks again,
Mark D. Fain
"dave chiew" <csaurus@tm.nut.my> wrote in message
news:vr2ea01331i2fl4mve83hsbujd13a4qaa0@4ax.com...
256
1200
> >DPI.
> >Thank you,
> >Mark D. Fain
> Mark,
> -Dave Chiew
