R rajatjob7 Apr 1, 2018 1 0 10 Apr 1, 2018 #1 hi in past wifi speed slow in my laptop so i did one troubleshooting by opening registry editor and inside it i open google chrome and increase the value from 0 to 4 but now again this problem occuring what can i do now
Solution Phillip Corcoran Apr 1, 2018 Google Chrome is probably the next worst browser after IE. I suggest you dump Chrome & use Firefox instead. Worth a try. Also, if not already using the 5GHz wireless band, consider doing so at it's generally faster than the more common 2.4GHz.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,107 912 120,140 Apr 1, 2018 Solution #2 Google Chrome is probably the next worst browser after IE. I suggest you dump Chrome & use Firefox instead. Worth a try. Also, if not already using the 5GHz wireless band, consider doing so at it's generally faster than the more common 2.4GHz. Upvote 0 Downvote Solution
