Hi all ... noob question incoming (sorry)
I understand speed step (CPU will throttle down if not needed)
I understand Turbo boost (CPU will throttle up if needed)
So when my PC is 3.3Ghz with turbo to 3.6Ghz.... why is the CPU speed not just 3.6Ghz? since It seems it can throttle down to whatever... and up to 3.6Ghz completely dependent on processor load.. so the 3.3Ghz limit seems arbitrary?
I understand that the turbo does have the caveat "as long as its cool enough and has enough power" but that's the same as ever.. even if it at its rated max.. if it overheats it will slow down.
My actual CPU is overclocked to boost to 4.2Ghz.. with water cool it always cool enough.. so is it not in effect a 4.2Ghz CPU with speed step?
But you would expect Intel to claim max speed they can.. so I expect I am missing something.
What is it please?
Thanks in advance
Cheers
What is it please?
Thanks in advance
Cheers
