Speed vs. latency?
src1425
199
When purchasing memory, what's more beneficial, higher speed but with higher latency (e.g., DDR3 2000 with latency 9) or or lower speed but with lower latency (e.g., DDR3 1600 with latency 7)?
Maziar
Champion
Well its a matter of taste really,some users prefer higher timings and some prefer higher speeds but DDR3 1600 is a good speed,i don't think you will need more than that unless you want to overclock your CPU to an insane speed
saint19
Polypheme
Hi.
Low CL + High speed = The best RAM.
In the example that u post, u won't see the difference between 1600 and 2000 in speed, but the CL is very high. In that case, the best option is the 1600 CL7.
Be sure that the RAM voltage is 1.65V max.
ekoostik
1,327
88
What type of application are you going to be running the most often - or what application do you care the most about? Check the reviews for similar apps on your platform and see what your app performs better with. Tell us what rig you're looking at and what type of application you care most about and we'll try to point you in the right direction.
src1425
199
Building a general-purpose rig for gaming, general productivity, and occasional video encoding. I only build a new system every 5 years or so, with some interim upgrades along the way, so longevity is key. I haven't done any OCing yet, but will probably give it a try with the new build. Just want to get the most for my money, and I noticed that some of the DDR3 2000 memory (with slower timings) was priced about the same as DDR3 1600 memory (with faster timings). I realize that faster speed AND low CL is the ideal, but between the two which is better? Or, based on the articles, perhaps I'm splitting hairs?
ekoostik
1,327
88
You're probably better off with 1600 and tighter CLs. On some platforms it's hard to hit 2000 MHz. Some even require you to OC to hit 1600 MHz - the i3 and i5 CPUs are an example of this.
There' very little difference in incremental steps up in speed, outside of synthetic benchmakrs. If you haven't seen these articles, they may be helpful:
Memory with socket 1156: http://www.tomshardware.com/reviews/core-i7-870-1156,2482.html
Memory scaling on Core 2, Core i7 (socket 1366), and Phenom II (the first page has links to individual articles for each platform): http://www.tomshardware.com/picturestory/511-memory-scaling-ddr3.html
Maziar
Champion
Can you post the full specs of both ?
src1425
199
First up, thanks for all the feedback - learning a lot! Not a lot of options from my QVL for 1600 with 7 CL:
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model OCZ3P1600LV4GK
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227482
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRH
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231279
G.SKILL ECO Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBECO
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231321
Or for CL 8 there's:
CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMD4GX3M2A1600C8
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145265&Tpk=CMD4GX3M2A1600C8
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-4GBRM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231278&Tpk=F3-12800CL8D-4GBRM
Kingston HyperX 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C8D3K2/4GX
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104141&Tpk=KHX1600C8D3K2/4GX
Kingston HyperX T1 Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C8D3T1K2/4GX
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104142&Tpk=KHX1600C8D3T1K2/4GX
OCZ AMD Black Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model OCZ3BE1600C8LV4GK
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227496&Tpk=OCZ3BE1600C8LV4GK
Any suggestions?
Maziar
Champion
In that list,I would go for this one
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231279&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
because of having a good combination of timings and speed
src1425
199
Depends on which day you ask! :)
I'm still debating between a 965BE or 1090T (due to the $50 discount on the latter at MicroCenter) and either an ASUS M4A89GTD PRO/USB3 or the Crosshair IV Formula. The 1090T and Crosshair IV are admittedly more than I need, but I don't might spending a little more up front if it helps extend the life of the system, and since it's unclear whether Bulldozer will be compatible with AM3 I'm tempted to get the 1090T.
saint19
Polypheme
In the tech world, the life of a gaming rig is 2 years max because always comes out new components with better features and a better price/performance.
Now, all this AMD processors are 45nm and as far as I know the 32nm processor of AMD comes out the next year with the new ATI GPU generation.
The 1090T and the Crosshair IV are very good options, but if u want safe a little more u can go with the same 1090T and the Gigabyte 890FXA-UD5.
src1425
199
I'm not a hardcore gamer (a wife and kids preempt that!) so upgrading every 2 years just isn't practical. Would rather get a system that will last me a good while, with a new CPU or GPU after 2 or 3 years. Will check out the 890FXA-UD5 though!
saint19
Polypheme
That's a very good reason (I have the same reason too).
In that order, AMD offer the best price/performance and future upgrades.
Check out the Gigabyte that have a very similar performance that the Crosshair IV.
Similar threads
