speedfan can not control fan?
matthi321
34
hello so im trying to control my fans using speedfan, i have two identical case fans. i can control the one that are plugged in the 4 pin connector, but the one that are plugged in the 3 pin connector i cant seem to control why is that?
The fourth pin on your fan connector is a control pin. This is why you can control the 4 pin ones but not the 3 pin.
oh well that suck. are their any other way i can lower the speed of the fan?
Some 3-pin fan headers support voltage control to adjust fan speed, the 4th pin is just enabling a different type of fan control called PWM.
If none of the 3-pin headers on your motherboard support fan control, you'd have to add a separate fan controller.
and how do i see if the 3 pin head supports voltage control?
that may be what i need. cant seem to find any place you can buy one in europe though. do you know i can buy one?
