i really need some help with speedfan and some of the sensors it has found.. most of them are in the 30-45 C range so i figure those must be correct.. problem is i do not know what they are detecting i have figured out the cpu.. but i do not know what the other are detecting
any and all help would be nice!!!
sensors i have questions about:
chip =lm84 sensor =local temp bus =nforce2 smbus
chip =max1617 sensor =local temp bus =i2cnvidia smbus
chip =max1617 sensor =remote temp bus =i2cnvidia smbus
chip =acpi sensor =called temp1 bus =isa
im guessing 2 might be my graphic card which is a leadtech 6800 gt and it does(confirmed) have 2 sensors but i do not know what they are
