SpeedFan Trouble :(( PLEASE HELP ! :(
Aug 26, 2018
9
Yesterday I downloaded speedfan to adjust my pc's fans but I think i did something wrong now all of my fans are working at 100% I only can control cpu fan when i restart my pc cpu fan goes on full speed It stops when I open speedfan, also can't control the other normal pc fan I tried everything removed SpeedFan cleaned all registry, reinstalled it again, removed bios battery reinstalled again tried to reset bios settings, there is only one option in bios setting It's only change fan's to automatic I enabled and disabled it but nothings works they all goes on full speed only cpu fan is controllable (only on windows)
My Hardware a little older but It's still useable 😀 help please 🙁
Specs are
Fujitsu Esprimo P700 E85+
Mainboard: D3061
GPU: GTX 750ti Pny 2gb
CPU: i3 2120
RAM: 6GB DDR3
SSD: 32gb
HDD: 1tb
PSU: 280W
I don't have that option 'Smart Guardian' my 2 fans are already manually controlled as i said only cpu fan Is controllable I checked my cpu's temps are 39-45 everything was normal yesterday until i downloaded this speedfan
did it now not works 🙁 I unplugged everything on motherboard like hdd ssd still nothing happens I'll try another cpu and case fan If that ain't work I have to get used with speed fan
I found an different solutions I tried another 4 pin fan it's same with my fans then i tried an 3 pin fan it was very quiet now i'm using an 3 pin fan for cpu and it works very good also ordered another 3 pin fan for pc cooling
