speedtouch wireless network problem
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.internet.wireless (More info?)
Hi Guys,
I was wondering if you could help me out with a problem I'm having. I
have an Speedtouch 570 wireless modem with a WinXP laptop and WinXP
PC. The PC is directly conected to the modem and the laptop via a
SpeedTouch 110 wireless card. I can ping the modem from both of them
and can also go on internet via both of them but can't access any one
of them from the other (no ping, file share, etc.). See bellow the
output from ipconfig from each:
[laptop]
Windows IP Configuration
Ethernet adapter LAN Wireless:
Connection-specific DNS Suffix . : lan
IP Address. . . . . . . . . . . . : 10.0.0.150
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.0.0.138
[pc]
Ethernet adapter Local Area Connection:
IP Address. . . . . . . . . . . . : 10.0.0.151
Please Help.
Thanks,
José
On 5 Aug 2004 03:24:02 -0700, jose.carballosa@hp.com (Carballosa)
If you can't ping each other, you can't share. Therefore, the problem
is why you can't ping each other. Some guesses:
1. You have the Windoze XP firewall enabled. Turn the stupid thing
off and get a real personal firewall.
2. You have ZoneAlarm, Norton Firewall, Black ICE Defender, or
similar personal firewall product installed. Turn it off temporarily.
If ping magically starts to work, there's you're problem.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
