Spiking Latency Need Help
Dron3r
5
hey guys so im having a problem where my net seems fine i go on each testing website it says my latency is fine and everything is all good as shown by these results:
http://www.speedtest.net/my-result/3733770035 http://www.pingtest.net/result/105437208.png
but everytime i go into a game in my example league of legends or path of exile my ping is spiking from 60-500-1000ms it never stays stable i have never encountered this issue before i have tried all the usual things resetting router scanning pc and even rang up my isp. i am confused because my internet seems fine but in game i just cant play any help would be appreciated thanks guys
you are using a router right?
Try this.
windows key + R
CMD
type in
ping www.google.com -t and play any game.
Next check back to this window.. If any of the pings show timeout or lag spikes you have a problem.
Check then ping to your router's ip address with -t argument too
ping 192.168.1.1 -t (or your routers ip)
and check again for timeouts or lag ms while gaming on LOL.
IF you get high ping or timeouts at that time it might be a problem with the router or your network adapter 😀
