Spilled water on k70 rgb
Zenrap_518
Commendable
Mar 1, 2016
28
2 days ago, i spilled a tiny bit of wayer on my k70 rgb while plugged in. It started to do random key imput like i oushed every key in the keyboard. I left it for an hour and it still did it.
I have since been drying it for 2 days. I just left it on my desk. I cannot test now but i hwve some questions.
Do i need more dry time? Do you think it will work or not? What do i do?
Not sure what else you are looking for as an option. If it's broken and they won't cover it under warranty, you need to buy a new one. If you don't...
Two days should be plenty of time for it to dry out fully. Will it work? Maybe. What can you do? Replace it.
Corsair does not cover user accidental damage. I do not wanna buy a new one.
Not sure what else you are looking for as an option. If it's broken and they won't cover it under warranty, you need to buy a new one. If you don't want to buy a new one, you won't have a keyboard. If it has water damage, you can maybe try to repair it by finding the base board and replacing the one in yours, but you already said you don't want to take it apart. If you can't or won't do anything to repair or replace it, your options are to have it sit at your desk as a sculpture, maybe paint the keys in some fun colors to make art, sell it as is for parts on ebay or craigslist, give it a burial in the back yard, drive over it with a car.
Ok then...
If it doesnt work, i will try a few methods on ripster's spill guide.
