Spilled water over computer tower..
Randhimself
23
So basically i spilled water over my computer tower (the top of it), and i dont have a "side wall" for the computer. However i turned the computer to the side and turned it off asap and let it run off, not hitting any hardware. I checked a moment later and saw that not a single water dropplet had touched the gpu, fans, motherboard, psu, cpu etc.. However it had hit one part, one of the harddrives, however it was only like a single drop that had hit one of the cables that goes into the hdd. I tried to boot the computer a few moments later, the motherboard etc seems fine since i can still access the bios. However it says "disk read error" when i try to boot it. I unplugged that harddrive and tried to boot on my other hdd, it worked. But i dont have windows on it..
Is my hdd RIP? Or can it be saved?
Also i dont have rice at home.. 🙁(((((
i left everything to dry for about 7 hours, and it's back alive right now. Im inside windows with both of the HDD's plugged in, anything i should avoid or anything i should do?
If it ain't broke, don't fix it. I would just check to make sure that you can fully power the system off and restart it without the issue coming back.
