Ok so I recently got SC : DA for my PC.
After I installed it , in the compatibility check , i had a green tick for everything except for driver version.
It said I needed Driver version 5919 or something like that.
SO i updated my graphic card driver from the nvidia site.
then when i run the game I can't put my resolution above 1024 x 768 pixels cuz the ratio doesn't go above 4:3
I usually play on 1360 x 768 (I know very low res but still)
later when i'm playing the game , sometimes when I'm in light my character and any other character model present starts getting all these innumerable red and yellow and green and blue (and you name it) colour dots on them.
My rig can play Splinter Cell Conviction on highest graphics at around 45-50 FPS and sometimes 60 or more.
After about 5 mins of playing SC : DA , a blue screen appears on my monitor and the PC restarts.This has rendered the game unplayable.Even though I have set the graphics to max the textures and lighting is comparatively very bad.
My PC Configuration is -
Windows XP 32-bit SP3
Intel Core 2 Duo E7500 @ 2.93 GHz
Nvidia 9800 GT 1GB GDDR3 Memory
2GB RAM
If any other configuration is needed to solve then please tell me.
Also the name of the file (latest driver) that I downloaded for my 9800 GT from the Nvidia site is -
280.26-desktop-winxp-32bit-english-whql
Please notify me if this is an incorrect driver for my 9800 GT.
Thank you for any future help!
2GB RAM
