Split USB ?
Rubenaasheim
118
Hey! i was wondering if i was able to kinda like split my USB so i have 2 partition on my USB so i can have my regular files on 1 partition and the iso file on the other one? and if im able to do that how will i get the BIOS to start with the iso installation?
you can have a windows installation and all the other files on the flash drive at the same time--i always do it i just make an extra folder called software and put the stuff in there
dont think you could partition a flash drive unless you can bit flip it so windows sees it as a fixed drive not a removable one
First of all you are talking about splitting your hard drive or flash drive, USB is just the connector.
Typically you would use a tool like Easus partition master and shrink the partition the iso is on, then create new partition for the data.
Now if you told me if this was a hard drive or a flash drive and what the iso is of (like is it a live cd of Linux, is it windows installation, is it your windows os on a hard drive, etc) then I can give you more specific information for your scenario.
its a flash drive and windows 7 installation :) sorry i thought i wrote that
I have never experimented with altering the partition size of the iso image. Cant say for sure if it would work or not.
Do you not have a second flash drive?
Here I 4 options before having to resort to this
1) another usb flash drive/external
2) transfer file to another pc via network or remove hard drive and "mount" it to another pc and then transfer files.
3) shrink partition of hard drive you are going to install windows on, and put your data on that partition.
Thank u !
