Split VGA signal without quality loss ?
ungovernable
BANNED
Apr 14, 2011
244
i wasn't sure where to post this question so im posting here, sorry if this is wrong category
I have a DVR computer with security cameras and i want to display the same image on another monitor. I only have 1 VGA output, so i really need to split the signal.
I bought a cheap Y splitter like this one
But i ended up not using it because there is an important quality loss
So i'm looking for an alternative without quality loss.
I found this from monoprice:
http://www.ebay.com/itm/2-Way-SVGA-VGA-Splitter-Amplifier-Multiplier-300MHz-/370543547116?pt=COMP_EN_Networking_Components&hash=item56461dd2ec
Will i see a quality difference with this item ?
Also, what is 300MHz? There is also 400MHz version for more money, is there a noticeable difference?
thanks !!
Yeah it's a DVR computer made with intel atom and a shitty motherboard with only 1 PCI slot and its already used by the DVR card so i cant get a video card. And there's only ONE video out on the motherboard
It is a DVR COMPUTER not just a DVR.
You can try using one of them Multiple Display Boxes, but they're not going to be that cheap I think.
You might as well just change the Mobo and Processor to a Llano Set. It'll be well worth the Headache. I really can't see an Atom keeping up with the Cam feeds..... I don't know how they managed it, but, I'd love to know the Model and make of the DVR Computer you have, specs would be good too.
I built that DVR computer myself.
back 2 weeks ago, i was using a Pentium4 1.6GHz with 256mb ram for running 5 cameras live.
I wanted something more silent without fan, so i upgraded to that :
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121442
With only 2GB Ram and it's doing the job very well with Geovision Software
Well i found some of them on ebay for less than $30, and newegg are selling one for $45
I just want to be sure there won't be signifiant quality loss like i had with a traditionnal "Y" vga splitter
