Spooler subsystem has encountered a problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I get the above message that "Spooler Sub system has
encounterd a problem and needs to Close" All of the
printer icons are missing and am not allowed to add new
printers without getting this message. ECP printer port
shows in Device Manager. Any ideas
Thank you
G
Guest
Guest
See the following KB article
http://support.microsoft.com/default.aspx?scid=kb;en-us;324757
Cari
www.coribright.com
"jstocka" <anonymous@discussions.microsoft.com> wrote in message
news:1711801c4181e$3b9b1040$a401280a@phx.gbl...
> Thank you
hans
71
Try this:
Go to the folder c:\windows\system32\spool\printers. If there are recent files, cut them to an other location (for backup if this doesn't work). Then restart Windows XP.
I had this problem and this solved it.
Good luck
> Thank you
abudala
10q hans
your solution << Go to the folder c:\windows\system32\spool\printers. If there are recent files, cut them to an other location (for backup if this doesn't work). Then restart Windows XP. >> worked
