Question Spreading out ethernet connections across all ports of a hub vs one and using a switch ?
trick97
12
I currently have a managed network switch that connects to one port on my Fibre Broadband Router/Hub
This switch has about 16 ports connected to it.
Does it make any difference to performance/reliability if i spread those connections out to the other 3 ports on the hub?
i.e. if i have 3 or 4 switches connected to each port, each switch had multiple connections, but there was less connected to one, if that makes sense.
Just curious....
kanewolf
Just curious....
If you are running as a layer 2 network then there is no benefit.
Do you have multiple subnets with a lot of traffic between them?
