Question Squeaky noise from cabinet
Jun 26, 2022
4
I am hearing squeaky noises every time playing game , and computer vibrates like starting an idle engine , but it resolves after turning gpu fan speed to 100.
PrivilegeYT
305
69
I could make some guesses, but it sounds like either a HDD cage is loose or the motherboard wasn't mounted properly with the standoffs. If you supply me with a video I might be able to narrow it down.
Jun 26, 2022
4
the problem started after i tried to clean my pc, didn't remove any components so motherboard one shouldn't be an issue. This is the sound it makes, I think its the hdd. Is it dieing? https://ucarecdn.com/1354ddbf-a54c-43d5-ab62-b1c960f517e7/
PrivilegeYT
305
69
I don't think it could be the Hard drive anymore because with a noise like that you should of been able to tell if the Hard drive was having issues with the platter. Honestly, your best bet is to start removing stuff and see what is causing the issue. Start with the GPU then work your way to the fan.
