(1) See NOTE at Bottom **. But here is the method - Have not done the "F6" with windows, up until now there has not been a need as Win 7 provided very good support drivers. Use to be a page that asked if you needed to install additional drivers prior to installing windows. From what I understan thats still there, just expanded on location of the driver. Back in the days of XP, they had to be on a floopy. Now they can be on a USB drive, possibly a CD.
(2) Did you already register (Activate) your installation? Not that it matters, this still only counts as 1 installation, No matter how many times you uninstall (wipe it) and reinstall.
(3) I'm quessing that family pac is the upgrade version. If so, you will need to select custom install to do a clean install - You can not upgrade without having the operating system visible, But with your HDD disconnected it will not be visible, BUT that is OK as you are allowed to do a clean install - BUT there are to hoops that you have to jump through when doing this - IMPORTANT - DO NOT enter your windows Key during install, also deselect - Activate automatically. WILL edit this post shortly with what you need to do.
** RST files and F6
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Chipsets&ProductLine=Chipset+Software&ProductProduct=Intel%c2%ae+Rapid+Storage+Technology+(Intel%c2%ae+RST)
Select operating s7ystem ie Win7 64, or 32. Down load the F6 and the Main file (on main file there are two choices the Larger file is multilanguage, smaller on (enu) is english only).
Right cleck the F6 file so that you can extract the files and then you can read the "Readme File" when selecting, you want the ahci driver.
** added: clean install using upgrade disk
From one of my previous posts.
Do a Clean Install, select custom method, But DO NOT enter your Key
Go ahead and let windows 7 down load critical updates. Then:
Open regedit.exe with Start Menu Search and navigate to:
HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/CurrentVersion/Setup/OOBE
Easier - Just do a search for " MediaBootInstall"
Change MediaBootInstall from "1" to "0". (Double-click it and then enter 0 in the dialog that appears.)
Close RegEdit.
Open the Start Menu again and type cmd in Start Menu search to display a shortcut to the Command Line utility. Right-click this shortcut and choose "Run as administrator."
In the command line window, type: slmgr -rearm
Then tap ENTER and wait for the "Command completed successfully" dialog.
Then, close the command line window and reboot. When Windows 7 reboots, run the Activate Windows utility, type in your product key and activate windows.
