Question SSD Drive Install Question Problem
Nov 30, 2021
33
I'm running a Asus ROG Strix Z690-A Gaming WIFI D4 Motherboard. I have three Sata drives running now. One Sata drive is C: drive I wamt to replace it with a Crucial P5 2TB PCIe M.2 2280SS SSD. Which slot do I use and will there be a problem reading my other two Sata drives which are used for storage. One is storage and one is for using VMWare for Linux.
Nov 30, 2021
33
The reason I'm asking if the Sata Drives will still read is when I installed the mother board I couldn't get the main sata drive to boot and Asus support couldn't figure it out. They refereed me to Microsoft which was a hand off. New drive configuration would be C;\Win11 (SSD), D:\ Data (Sata), E:\Virtual Drive (Sata). Do you see a problem in doing it this way.
USAFRet
154,692
11,259
176,090
24,154
Yes, the drives will still read.
But if you transplanted a drive+OS from a different system, not booting in the new system is a common outcome.
A new motherboard generally requires a fresh Windows OS install.
Linux is more forgiving.
rwh531
24
I am using the same board he is and i believe sata 5 and 6 get disabled with the use of certain nvme slots, also windows 11 seems to be much more forgiving when it comes to transplanting a drive without reinstalling windows
