I Inquiring2016 Honorable Feb 3, 2016 20 0 10,510 Mar 18, 2016 #1 Any suggestions for a 120 to 250 Gb SSD that is reliable and reads and writes as fast as possible for WIN 7 OS and an Intel i7 gen 6 CPU?
Solution Rogue Leader Mar 18, 2016 Samsung 850 Pro http://www.newegg.com/Product/Product.aspx?Item=N82E16820147360&ignorebbr=1&cm_re=Samsung_850_pro-_-20-147-360-_-Product Unless you want to go M.2 in which case: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147466&cm_re=Samsung_950_pro-_-20-147-466-_-Product
2 2Be_or_Not2Be Distinguished Aug 23, 2013 1,130 167 19,940 Mar 18, 2016 #2 Samsung 850/950 & Sandisk Extreme Pro - my current favs, consistently at the tops of the performance charts. Other nice ones are available at cheaper prices (or even a bit higher, if you go the Intel 750 route). Upvote 0 Downvote
Rogue Leader It's a trap! Moderator Dec 22, 2014 33,376 3,239 116,640 Mar 18, 2016 Solution #3 Samsung 850 Pro http://www.newegg.com/Product/Product.aspx?Item=N82E16820147360&ignorebbr=1&cm_re=Samsung_850_pro-_-20-147-360-_-Product Unless you want to go M.2 in which case: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147466&cm_re=Samsung_950_pro-_-20-147-466-_-Product Upvote 0 Downvote Solution
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,817 1,871 159,590 Mar 18, 2016 #4 One of the Samsung's for sure. https://pcpartpicker.com/parts/compare/samsung-internal-hard-drive-mz75e250bam,samsung-internal-hard-drive-mz7ke256bw/ Upvote 0 Downvote
