I have an Asus G74s that has 2 500GB WD HDD installed both have failed and are no longer working. I am looking into buying a 120GB Kingston SSD. My question is i have no operating system but i do have a windows 8 installation disc and key. Can i plug in the fresh SSD and then boot from my disc drive? Will the computer be able to partition the SSD or will i need another computer to setup the drive first? Thanks for any help!
If it helps this is the SSD I'm looking at
http://www.newegg.com/Product/Product.aspx?Item=N82E16820721107&cm_re=internal%2bssd%2bhard%2bdrive-_-20-721-107-_-Product
