Hi,
My OCZ Vector 512 GB SSD recently stopped working. I connected it to other computers to see if it worked on them (I tried with a SATA to USB converter as well), but it didn't. It would occasionally show up in the BIOS when it wanted to. It never showed ever in Windows Disk Management or Fedora Disk Utility. I listened carefully and It would make faint beeping sounds of 2 different pitches. I opened it up and identified the source of the sound to be two SMD inductors soldered onto the board.
The Drive Activity LED on the case would blink in sync with the beeping sounds. It would only make the sounds when the SATA data connector was plugged in. With only the power connector plugged in, it makes no sound. What could possibly be wrong with this SSD and is there any way I can try and fix it?
Thanks.
Thanks.
