Hi community!
I've got a 2.5" SSD which I'm trying to pull data from. It's normally an internal drive which was removed from a laptop. I've tried using a regular SATA to USB cable, which I know works as I've used it with regular spinning HDDs in the past. However, when connecting the SSD, nothing happens. The adapter is found, but not the drive.
Now, I noticed that the SSD is rated for 5v and 1.6A. This amperage seems like it's more than could be provided by a USB port. Could the drive not receiving enough juice be the answer to my problem?
Thanks!
Thanks!
