ssd problem|Soft ECC Correction Rate
eghost99
26
hello, couple a days ago i bought kingston v300 120gb ssd,
after i copied my c drive into it i ran hdd scan utility and got this problem
what should i do?i need to go to the company that i bought it from them and replace it?thanks to the helpers
I'm going to suggest re-running the test (long version if available). I have seen where some errors that initially show, have "fixed" themselves during later SMART tests... doesn't make sense to me either. The values showing look to be correct which is why I'm suggesting to re-run.
Hi, I'm Jewel with Kingston Technical Support. That was a false alarm, attribute 204 reads ‘120’ until a sample size between 10E10 and 10E12 is available to be tracked. Information of the normalized values and their descriptions can be found in our SMART Attributes PDF here: http://media.kingston.com/support/downloads/MKP_306_SMART_attribute.pdf
Thanks for choosing Kingston as your upgrade partner.
Which would explain it's apparent "self healing" properties - good info
