Hi, I really don't know much about SSD's so I was wondering if somebody could point me in the right direction.
Basically, this is what I am looking at. https://www.amazon.co.uk/Western-Digital-WDS120G2G0A-Internal-Green/dp/B078WYS5K6/ref=pd_sbs_147_2?_encoding=UTF8&pd_rd_i=B076XWDN6V&pd_rd_r=8495f5fe-ef07-11e8-9b97-b1c6d07c4ee4&pd_rd_w=7zVBx&pd_rd_wg=0NLRw&pf_rd_i=desktop-dp-sims&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_p=18edf98b-139a-41ee-bb40-d725dd59d1d3&pf_rd_r=KDTTW0C0Y6JBCY2ZS815&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&refRID=KDTTW0C0Y6JBCY2ZS815&th=1
1) What is the difference between the stick looking thing, and the actual SSD (2.5 inch option vs M.2 2280 option) are they both as fast as each other?
2)My motherboard is a MSI B350 Gaming Plus, would this support the stick.
3) If I bought the stick version is it just a case of plugging it into the motherboard and going?
Sorry for all the bad questions, I literally know nothing about SSDs 🙁
(Also my budget is quite tight that's why I've gone for a cheap one!)
Thanks guys!! 😀
Thanks guys!! 😀
