ssd will not boot with my system iv tried everything i can think of please help
Quey647
Commendable
Jan 6, 2017
4
Ok so basically, i recently built myself a brand new pc. All parts were bought brand new..... Execpt for the harddrive, i figured i had a decent sized harddrive in my old computer which was a western digital blue 500gb with all my old computers stuff, i used it and it worked fine until i realized it was bottlenecking my system when disk usage was at 100%. Naturally my first thought was "well il get a nice sized ssd and keep the hdd as storage" so i went out to the store and bought myself an SP Super sata 3 ssd, 240gb in space. I went on youtube and got to watching all the videos on how to clone drives and i am almost certain iv done it correctly. But i keep getting different errors lik "windows has failed" and so on so fourth. Iv been troubke shooting for 3 days now with no real progress other then loosing all my files when I finally decided to reinstall windows 10 and not keep anything because the other options were not available and didnt even give me an option to put it on my ssd as windows 7 would... I also has trouble getting the disk to even boot off the start screen so i had to run the install windows 10 package inside of windows. I tried playing around in the bios changing from ide to ahci i think it was which is what one person said. My system almost bricked earlier and i thought motherboard was faukty but fixed that by turning on and off from psu while holding on button again from a guide. Iv tried recloning, using different software, checking compatibility online, unpluging then trying to install which would not work because the cd would not boot to install windows without the harddrive . Im honestly so frustrated and im wondering if its a compatibility issue . Coming in this site is all i got left really.
MY COMPUTER PARTS ARE
AMD FX6300
Gigabyte 78MT-USB3 Motherboard
Western digital blue 500 gb
SP sata 3 SSD 240gb
gtx 1060 3gb
If you were trying to boot from the old hdd (if it has an OS on it), you should do a clean install of windows
Which you've done now
So you changed the bootdisk in the bios to the windows dvd saved settings, and that didnt work either?
What happened when you tried to boot from the windows dvd?
You should put it AHCI if you install Win7 or 10.
Unplug the other hdd then try and install on the SSD
So you tried to clone from HDD to SSD?
Questions:
1. What software did you use?
2. What size/make/model is the SSD?
3. How much total used space is in the current C drive?
4. Can you return the system back to original working condition with the original HDD?
i tried unplugging the hdd and installing the operating system and all i got was a message saying "windows has failed" then it tells me to put in a windows cd and when i tried to the same thing happened almost like it could not read the disk without the hdd for some crazy odd reason
i think il retry what you said and get back on this post
ok so basically, i did that and i thought it was gonna work when i saw it booting but when i tried to install it said "The computer started using the Windows installation media. Remove the installation media and restart your computer so that Windows starts normally. The, insert the installation media and restart the upgrade. (DO NOT SELECT ICUSTOM (ADVANCED)I TO PERFORM AN UPGRADE. Custom (advanced)i installs a new of windows and deletes your programs and settings.
OK SO, i was not able to clone and keep my data. HOWEVER! I was finally able to boson my SSD and when i got the error i said in my latest or second latest message i went with custom and everything installed fine, i thank everybody for helping i love this community and if i have any further problems il be sure to update!
