Hello there!
We have: Samsung Evo 860 from office with Elementary OS and Samsung Evo 870 from home with same OS. Both are 500GB.
About a year and a half ago I bought an 870 and cloned an 860 to it using CloneZilla, everything worked great.
Issue:
I took an office drive and put it in my computer, but it refused to work until I disconnected my home drive, there was a black screen with blinking underscore.
After a working day, I connected my home SSD back, but it is not visible in the BIOS and Windows. After some manipulations, for some reason, it began to appear in Windows Disk Management, but nothing can be done about it: an input and output error.
Tried to use EaseUS, it was able to detect the free space and EXT4 file system, but the operations also showed read/write errors.
Through CloneZilla, from time to time this disk is shown as 0GB and without a serial number, otherwise it gives a read error at startup.
The software for updating the Samsung firmware also does not see it, just like the Samsung Magician.
I tried to do something through the Live-CD terminal, but no luck here either: errors in reading the superblock.
Before disconnecting the drive worked fine this night.
I need to at least make it work in any way, I don't care about data loss. Any advice?
UPDATE: I will no longer torment the disk myself and tomorrow I will give it for diagnostics under warranty. But still ready for hearing any advices, explanations, theories etc
Issue:
