SSHD a bit too big, is this a problem?
Bill_83
Commendable
Jul 5, 2016
Hello all,
Recently I bought a new sshd for some more storage, and performance. Upon receiving it I noticed that it was slightly bigger then my original hard drive. I was able to fit the sshd into the laptop, but I notice that the keyboard is a little raised over the area where the sshd is. Is this bad for my computer?
Thanks
well looks like your laptop uses the thin SSHD ones.
thin SSHD are slimmer than ordinary SSHD.
It wont effect the performance but it will just look weird I can't imagine how it would ever be able to break your laptop. Also did you check to make sure it is positioned correctly?
well, my laptop is currently using the sshd. so I assume it is in there correctly.
