[SOLVED] Standard led strip compatible with Icue?
jessicat1261
Commendable
Jan 14, 2021
62
So I have an aura sync compatible 4 pin header on my motherboard , and the motherboard also appears in Icue, so I was wondering if I got a 4 pin led strip will it be compatible with Icue? I'm guessing it'll show up but won't let me change the rgb options other than the built in colours? (What I mean is wil it let me customise it like you can in Icue or not? I presume not since its an rgb strip not an argb but worth asking about.)
