How To
Stardew Valley “Goblin Problem” Story Quest Guide
Story Quest Information:
Quest Name: Goblin Problem
Quest Text: There's a goblin blocking the path to the Witch's hut. There must be some way to get him to move... Perhaps I should seek out more information on Goblins.
Provided by: Through the cave by the Railroad after completing the Dark Talisman quest.
Requirements: Speak to the Henchman outside the Witch's hut and give him Void Mayonnaise as a gift. Take the Magic Ink from the Witch's Hut and give it to the Wizard.
Reward: Wizard buildings available. Dark shrines now accessible in Witch's Hut.
This is the last quest of Stardew Valley and it is a little bit challenging but not that hard to complete. Just follow the instructions that are mentioned in the walkthrough below and you will be able to complete this quest in no time. So without further ado, let’s get started:
Walkthrough:
The quest starts after you complete the quest Dark Talisman by talking to the Goblin. You need to get the magic ink for the Wizard and for that you need to get access to Witch’s Hut. But the passage leading to that hut is blocked by the Goblin. To make the Goblin go away, you need to give him a gift. To know what the gift is and how to make that gift, read the step by step instruction below:
1.To get the ink from the hut of Witch, you need to first pass through the Goblin that is blocking the passage. Now to pass the Goblin, you need to gift him Void Mayonnaise.
2.If you do not have the Void Mayonnaise, then there are two ways to get it. The first way involves getting the Void Mayonnaise by fishing in the Witch’s Swamp. But there are very low chances of getting it through this way as the guarding Goblin reduces the chances of Void Mayonnaise.
3.The second way of getting the Void Mayonnaise is first to get the void egg. After you have the void egg, take it and then place it inside the mayonnaise machine. This will create the Void Mayonnaise.
4.Once you have the Void Mayonnaise, go to the Witch’s Swamp and then go near Goblin and give him the Void Mayonnaise as a gift. Once he gets it, he will go away and then you can go ahead.
5.So after the Goblin has gone, go straight and you will see a hut, it is the hut of Witch.
Go inside and then take the magic ink that is sitting on the table to your left.
6.Once you have the ink, go to the portal behind you and then take the stairs to your left, you will directly reach the tower of the Wizard. And then there will be a dialogue exchange between you and the Wizard and after that, he will give you your reward which is the book that has Wizard Buildings.
The quest is not as simple as one might think. There is some work involved in completing the quest and you must have to gift the Void Mayonnaise to the Goblin to get access to the hut. Now the real work is in getting the Void Mayonnaise. But once you get it, it will then be easy for you to complete the quest. Just follow the steps of the walkthrough above and you will easily complete it.
