Start low and upgrade later, ideas?
mizz
Commendable
Apr 23, 2016
Hello everyone,
My laptop is almost dead and unfortunately I'll have to move on soon. It had a fan problem which I changed 3 months ago but now it started making almost the same noise as before which means is going down. (my fault, I shouldn't have played the witcher on it)
I've been planning to build a pc but kept waiting and waiting but now it's time to start looking into it and get some pieces.
The laptop is: intel i7 2630QM, 8gb ram, Amd Radeon 6770m.
I already have a 240gb ssd and a 3tb external hard drive so for the beginning I can use the ssd and keep the external hdd in a usb port until I will upgrade.
Approximate Purchase Date: as soon as possible
Budget Range:600£ with shipping
System Usage from Most to Least Important: gaming, watching movies
Are you buying a monitor: Yes
Do you need to buy OS: No
Preferred Website(s) for Parts: don't know, I'm in the UK so maybe something local which will be easier for delivery
Overclocking: Yes
SLI or Crossfire:/ No
Wanted Monitor Resolution: 1920x1080 or 1920x1200
I think I checked all the boxes. Add a better CPU cooler later if you want to overclock. A little over budget, but you may find you won't need to upgrade for quite some time with an i5/GTX960 combo.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor (£160.99 @ Amazon UK)
Motherboard: ASRock B150 GAMING K4/HYPER ATX LGA1151 Motherboard (£108.38 @ Amazon UK)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2133 Memory (£32.45 @ Ebuyer)
Video Card: Gigabyte GeForce GTX 960 2GB Video Card (£147.95 @ CCL Computers)
Case: Xigmatek Recon ATX Mid Tower Case (£26.73 @ CCL Computers)
Power...
Power Supply: XFX TS 430W 80+ Bronze Certified ATX Power Supply (£31.99 @ Amazon UK)
Monitor: Asus VC239H 60Hz 23.0" Monitor (£119.32 @ More Computers)
Total: £627.81
Generated by PCPartPicker 2016-04-23 19:02 BST+0100
take a look here:
PCPartPicker part list: http://uk.pcpartpicker.com/p/VkRwwP
Price breakdown by merchant: http://uk.pcpartpicker.com/p/VkRwwP/by_merchant/
Motherboard: ASRock H170 Pro4S ATX LGA1151 Motherboard (£69.99 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£39.90 @ Amazon UK)
Video Card: Sapphire Radeon R9 380 4GB NITRO Dual-X OC Video Card (£169.99 @ Novatech)
Case: BitFenix Nova ATX Mid Tower Case (£26.99 @ Novatech)
Power Supply: Super Flower Golden Green HX 550W 80+ Gold Certified ATX Power Supply (£57.12 @ CCL Computers)
Total: £676.75
Generated by PCPartPicker 2016-04-23 19:49 BST+0100
