Start menu and Cortana not working: PowerShell wont recognize commands.
xenonphantom
25
My windows start menu and cortana are completely not working when I click on them. My Microsoft settings are not opening either. When creating other users on my system and logging onto that user, it is just a black screen with a cursor.
I looked for solutions and found many articles and most solutions start with a command Get-AppXPackage. I was following solution 2 in this article:
https://mspoweruser.com/solution-start-menu-not-working-windows-10/
When I copy the command in I get this:
http://imgur.com/a/8MGtc
I have been trying to fix this problem for a few days now and it is extremely annoying. I don't want to resort to a windows refresh at this time so a better solution would be appreciated.
I'm sorry we couldn't get it fixed an easier way, but I'm glad you did get it fixed. Sometimes that's the best way and now you (hopefully) have a clean fast moving Windows. You don't have to select one as an answer since I couldn't help. Take care.
Hi, have you tried running the [System File Checker] from command prompt yet? It fixes corrupted and missing Windows files. Right click on Command Prompt and choose Run as Administrator, then type in SFC /scannow. You may need to run it several times. Reboot afterwards.
How about the [DISM] command? Reboot afterwards.
Also in the screen shot you posted of the powershell solution, you forgot to type the first G. It should be Get-AppXPackage and you left the G off. Try again and be sure you copy/paste the full command.
If none of this helps, reply back.
Hey, sorry in that screen shot I missed the G, every other time I tried I had it typed correctly. I edited the post and added a screen shot where I had the G and I get a similar message.
I have also tried both SFC and DISM commands multiple times and let them run. End result they say everything is fine even after reboot.
I also used the start menu troubleshooter and it says that "Microsoft.Windows.ShellExperienceHost and Microsoft.Windows.Cortana need to be installed correctly"(hence why I started to follow this article to fix the problem). It also says the tile database is corrupt.
Do you have System restore running and have you tried a system restore point?
Have you done a full virus scan and malware scan?
One option is create a new user account. Do this and see if the Start Menu and Cortana are working correctly in there. Read the 2nd answer on [this page].
[More good reading] (Tile Database is Corrupt)
About the powershell command... do you have the Windows Firewall service running? Read [this page].
This may require you to uninstall (or completely disable) any other Firewall you currently have running.
[Other potential solutions] Maybe you've seen this already? There's alot of reading there, I went through 5 pages of it searching for an answer.
Let me know what happens.
I decided to reinstall windows since it will probably take less time to do. I have tried for countless hours to fix it. I tried everything you suggested and what others suggested and nothing works or is always stopped by something. Thanks for your help, I will pick your answer as best.
