Start up problem
Srinivas_3
Hey hi people !! I have been using ACER laptop for the past five months (E55717776) where my laptop is gettiing delayed to star up,all I see is the light been flicked for five mins or more,but once it turns on m not facing any issues its working perfectly fine.Do suggest me with this.
Hi,
Please do try these troubleshooting steps that may help.
- Start by disabling all the startup items.
- Go to Task Manager then click on Startup tab and disable your startup items, reboot your laptop once done and see if it's a lot faster than before.
Also disable the Fast startup from Power Options.
- Go to Power Options and on the left pane click on Choose what the power buttons do.
- Once open click on Change settings that are currently unavailable.
- Then under Shutdown settings remove the check on Turn on Fast startup and click Save changes.
- Do test your laptop if it will be a lot faster on boot up.
