Start up problem
Beesler
How do I get windows 8 to start I have tried everything all the key combinations and it doesn't seem to work all it does is click a few times and goes back off no screen even shows
I read through different post and most seemed to point to memory issues so I switched the memory from one slot to another and now it is working fine. I appreciate your responses thanks​ (this is probably not the way to answer but I am new to this so kindly over look it this time.) thanks again
Looks like it's the computer and not Windows 8. First thing to look for is BIOS beeps... if they are sounding out, listen for beep codes... If no beeps are heard, does the computer have a speaker/beeper?..
Assuming there is a speaker and it's not emiting a sound: hard drives click usually once at a time when they are not getting enough power from the PSU... it's the HDD switching on or off and it may keep running... in my experience this has been caused by poor molex pin contacts.. but theorically a bad or weak PSU could cause the HDD to switch on-off from poor power feed. If this goes on, the motherboard may not get enough amps to load the display or keep running.
A second possibility is the BIOS may be corrupted so a Reset would be the first thing to try, second a more thorough BIOS reset extending the reset time, and if a reset doesn't help, restoring the BIOS may be necessary.
A third possibiliity is the CPU may be overheating.
A fourth possibility is the motherboard may have failed.
1. PSU TESTS:
a) Check the PSU connections to the motherboard including the HDD power connector.
b) Try a different PSU
2. BIOS REPAIRS:
a) Reset the BIOS with battery removed from the motherboard, the AC Cord removed and wait 10 minutes before reinstalling the battery, reconnecting AC power and powering up the computer. If this fails, Restore the BIOS.
b) Restore the BIOS according to motherboard brand and model instructions, or remove the AC cord, remove the BIOS battery, remove the BIOS *jumper, press and hold the power button for 60 seconds... replace AC cord, battery and jumper and start the computer.
c) if both resetting and restoring the BIOS don't work, you could repeat each extending the time to do a more thorough job. A reset can be extended to an hour and in some cases up to overnight... a restore which is basically a more complete reset can also benefit allowing more time as if you were reseting it... and you could look for manufacturer instructions on restoring the BIOS.
3. CPU OVERHEATING: Check the cooler fan runs at normal speed, replace the thermal grease if the computer is more than a few years old or if you have removed or reseated the heatsink.
4. MOTHERBOARD FAILURE:
If all tests have failed to restore display or continued running, fans, leds, etc.
*Don't forget to which pins the jumper is normally connected to.
Well, in most cases when it's this type of memory issue, there are no clicks, no beeps, and the computer doesn't go back off, all fans remain running and the display remains blank, and it usually doesn't happen after the computer has been running normally for some time, it normally happens after ram modules are improperly installed.... so the way your computer reacted to this ram issues is new to me.
As far as I know there are no forum rules for a way to answer... but feed back is always helpful for future advice and more people can benefit from reading your feedback so thanks for taking the time to explain the solution.
