Case- NZXT Phantom 410 Series CA-PH410-B1
Cooler- Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
Motherboard- ASUS MAXIMUS VII FORMULA
PSU- CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91
GPU- MSI GTX 970 GAMING 4G GeForce GTX 970 4GB 256-Bit GDDR5
RAM- G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
CPU- Intel Core i7-4790K Haswell Quad-Core 4.0GHz
HDD- WD BLACK SERIES WD2003FZEX 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5"
SSD- SAMSUNG 840 EVO MZ-7TE500BW 2.5" 500GB
Optical Drive- ASUS Black Blu-ray Drive SATA Model BC-12B1ST/BLK/B/AS – OEM
I've been looking over everything and this looks pretty good.
I'm gonna go with triple monitors- so the 4GB GPU should work well for me.
But should I go for water cooling? Maybe the H220-X or Kraken X61?
Thanks for any advice!
