startup repair issue
masterkiser
60
Recently my PC has started acting up, I got on one morning and was greeted with a startup repair screen. I haven't downloaded anything recently and I honestly don't know what's going on. I've tried every option except the command prompt (I don't wanna mess it up any worse) I tried to reset it to factory default and it said it encountered an error. I tried Restoring to a restore point but that didn't work either, I also tried safemode. I went on Microsoft and got a download of windows 10 to see if that helped but it didn't help at all. I'm pretty stumped and I cant find a solution online so any help would be appreciated. thank you for your time.
It's worth noting that if safe mode will not even run, that suggests a hardware problem.
Test the hard drive with SeaTools for DOS as I suspect it may be on it's death bead:
http://www.seagate.com/gb/en/support/downloads/seatools/
Put your Windows disc in the drive and boot off it.
Wait until it boots, then select your language & keyboard and then you should be greeted with some options, amongst them a "Repair" click that, wait for it to finish and reboot when it is done.
where is this repair option as I seen it in other help suggestions but I can't see it on the advanced startup screen options: https://www.tenforums.com/tutorials/2294-advanced-startup-options-boot-windows-10-a.html
I know there was auto repair in Win 8 but its been replaced by start up repair in win 10
I have noticed that safe mode isn't always available booting off the installer or without being in windows first.
What I would do is use http://www.howtogeek.com/howto/windows-vista/use-ubuntu-live-cd-to-backup-files-from-your-dead-windows-computer/ to copy anything off C drive you want to save and try a fresh install with the installer you made. Linux at least tell you if drive working okay.
I said 'Use a W10 CD to boot' not boot from your HD. That won't work.
Here is a simple guide to follow:
http://pureinfotech.com/repair-master-boot-record-mbr-windows-10/
That should do the trick. Give it a go.
